Posted 6/9/2019 22:53 (#7550737 - in reply to #7550295) Subject: RE: How do you mix your whole corn and pellets?
Central Nebraska
We had a similar setup when we were feeding. We would load the gravity wagon with corn and weigh it. The rest of the mix came from bags or buckets. We took the time to figure out ingredient weights in the buckets ahead of time. Worked well most of the time. Usually ran 2 or 3 squirrels up the auger when we fired up. Around here even junk grinder mixers are expensive
