Search Forums | Classifieds (85) | Skins | Language
Ag Leader ISO on Case FLX Sprayer
Caseih584
Posted 6/8/2019 08:45 (#7547665)
Subject: Ag Leader ISO on Case FLX Sprayer
I'm looking for information on where i should start to look for a problem or if anyone else has run into this problem this year possible. I Did a Gen 1 liguid to Gen 2 Liquid conversion on an FLx Sprayer 610 spray body. Suddenly here in the last two week sometimes when you start a job the two of the section butterflys are not opening up but the bladders in the ridgeways are opening when in Auto Swath. When it does this if you go out and reverse the Air lines on the Valve block they will open and you can spray in manual. Sometimes changing jobs or restarting the monitor will make the problem go away. I partly think it maybe because i am on version 4.0 on the inncomand 1200 but i also think if it was that i would have had this problem earlyer in the spring not here at the end when we will be about done spraying with sprayer for a little while.TIA
