south-central Nebraska | What did you use for soybean herbicide last year? The limp leaves and white banding on the leaves look similar to Flexstar/Reflex carryover symptoms. Have seen it in the past, especially if it is dry after application or when it is sprayed late since it has a 10 month rotational interval for corn. Can stunt plants and cause some unevenness, but should grow out of it. | |
