Best tool to enlarge a double sided heat/ cool vent 1/2 inch on both side studs
WHYNOT
Posted 6/6/2019 17:45 (#7544944 - in reply to #7544670)
Subject: RE: Best tool to enlarge a double sided heat/ cool vent 1/2 inch on both side studs
If it were me I’d use a multi-tool, a chisel, and something to block off the bottom of the hole if the ductwork is below where you need to cut.. You may find that you need to offset the two registers since there may not be enough depth for two registers to fit back to back.
Edited by WHYNOT 6/6/2019 17:45
