Search Forums | Classifieds (206) | Skins | Language
New holland LS230 skid starting issue
Klepto563
Posted 6/6/2019 11:57 (#7544514)
Subject: New holland LS230 skid starting issue
Hi everybody I am at wits end with this machine. It was running fine then ... nothing... This has happen to me before but my last fix I did is no longer working. So what it does is when I go to turn over the machine it wont activate my starter. The last time this happen i changed out my Main Power Relay and boom works just fine. What it does is I turn the key to on and after a few seconds it gives me a reading of "Volts", it then displays the volts jumping around from 11.2 to 11.9. I checked the relays in the cab and I checked the relay for the starter in the rear. All seem to be getting power to them. I've also tried putting a jump starter to the battery to see if it was not getting enough power but it still does the same thing. Any help to this issue would be greatly appreciated. I have the service manual and can screen shot any parts that may help me fix this. Im just lost.
Edited by Klepto563 6/6/2019 14:35
