SE Manitoba | Billyfox - 6/1/2019 17:45
Planning to pick up with a bale wagon.
It’s from the Kamloops area and does have the extended chamber makes it long.
Haven’t figured out a good way to get in on the trailer yet, it’s pretty wise
Take along 4 - 2 x 10" planks (rough would be even better).
Park the trailer so that the wheels are in the ditch or some other sort of drop.
Likely best if trailer is jack knifed.
Put planks on end of trailer 2 deep under tires.
Carefully pull the baler onto the wagon.
Fasten securely and flag end (important).
Hopefully your wagon will let you drive 100 kmph otherwise its going to be a slow boat home. |
