8 row vacuum here too. Mine is down to the outboard wheels doing the work. Seems ok. But, my soils are sandier type and slick conditions are rare. Did a whole rebuild on it last year, I just torched out the hex shafts and started over fresh. For the amount of rust and scale and each bearing hopelessly fused to the shaft... the 90 bucks for replacement shaft was a no brainer. IIRC, the only thing that locks the shaft is the coupler pin at the transmission. The hex bearings are slip through, with no locking provision. The drive lug ratchet will be set screwed to the shaft, and possibly hopelessly fused to the shaft as well.. So cutting everything out in bite sized chunks made it easier to heat and press off the re usable stuff in the shop. Got replacement hex shafting from Shoup. I had 2 modules and their frame brackets extremely worn on the pivot part, so I took some 3.5 and 3 inch round tubing, .25 wall, about 3 inches wide.. with ZERKS. Welded the 3 inch to the frame bracket, the 3.5 to the wheel module. I had to move these to the inside location because the bearing pocket was totally gone. That's why I only run the 2 outboard drive chains. Cant put a chain on an unsupported shaft. Now there is a 3 inch wide bushing surface as opposed to the factory 1/2 inch.. plus mine are now greasable.
Edited by rancherman 5/25/2019 06:36
