Posted 5/24/2019 10:09 (#7517697 - in reply to #7517653) Subject: RE: Hagen's Brew on a carburetor
Well, I have not found a carb cleaner that will do the job. On the high speed jet in this carb the holes are really small and you need to use a small wire to poke the gunk out. I would like to try something that will not require the use of a mechanical tool so I don't have to worry about damaging the jet. I figured Hagen's Brew was worth a try.
