Posted 5/24/2019 10:14 (#7517710 - in reply to #7517586) Subject: RE: Removing IH Rear Wheel Wedges
nesd
you need to rotate the axle so wedge is on the bottom that takes the weight off it then smack the bolt with a hammer it will come loose im assuming you have it jacked up it will only loosen one of the wedges then you need the clamp that goes on both sides to run the loose wedge against to break the other one loose
