Posted 5/24/2019 11:34 (#7517919 - in reply to #7516250) Subject: RE: Plastic or Sisal twine?
E.Central MN
The plastic twine used in round balers is thinner than sisal so you might need to tighten up the tension device depending on how it holds the tension on your JD.
