Eastern Ohio | Yes I have the same problem with mine. Had Corp. trouble shooter out and thinks its a program problem. Me and local dealer think that the roll holder was welded on in wrong position. Also they have installed that accumulator valve on the tie arm which may need adjusted. As far as pickup I pulled my drawbar as far as possible to the right, that helped a lot. I've been running all Vermeer hay equipment here but they have a month to fix it or its going back and I'll be looking at an Anderson. | |
