Maryland | Bought a used 1795. Don’t have a operators manual yet. Planted about a 100 acres of soybeans. Target plant population is 150000. I’m averaging around 147000 after counting my seed. My vacuum is running between 9.5 &10, Tank pressure is 15lbs., ground pressure target is 60.Planter runs between 50&70. Air tank pressure is 160. Planting notlll ,front units blades measure 14.75 ,I’m running in 3-4 setting for depth.Rear blades are 15” . Running them in 3-3 settings. Swath control is set for limited skip 100% on exterior,interior,and overlap. Turn on is 1.3 and turn off is .3 . Distance from hitch to rear of planter is at 25’ . Running one rubber and one cast closing wheels. Running in the lightess setting. Are these settings inline with everyone else? | |
