EC GA | I don't know about the hitch not raising, and don't think that there is any connection to what you did. If the remote outlets work, there is hydraulic pressure to the rear, and any problem with the hitch is either internal to the valve, or linkage related. Back to the pto, with the tractor shut off, you should be able to turn the shaft. It may be fairly stiff, but it should turn. If it's real hard, you have a problem in the clutch. | |
