NE North Dakota | 2013 - 36 row 20 inch
Overnight the right hand wing wheels will settle until the units are sitting on the ground. Also, when the planter is in the folded/transport position the wing wheels (both sides) will settle down in minutes (you can visually see the cylinder leaking back down/out) after I have "tucked" them up for transport.
I have no idea where to start looking, I am guessing it is an o-ring or valve that is malfunctioning. I have no exterior oil leaks on any raise/lower cylinders. The only drip that I have is from one of the two hoses that comes down from that valve stack near the rear ladder above center frame tires. We did remove wing cylinders this winter and placed them in a 30 ton press over night with caps on the fittings and they did not move a mm.
Does anyone have a diagram or able to point me in the right direction?
Edited by eastndfarmer 5/22/2019 10:43
