sw ontario | On small frame Magnum the engine oil pan drain goes out the side of frame through banjo fitting...hardly any room to get hand in , how do you replace banjo fitting...loosening oil drain cap it twisted that little metal tube like a licorice stick....I see there is a place to use 2 wrenches to loosen it but nearly impossible to get wrench & socket both on at same time...What do you guys do? Would have been so easy to copy deere & put oil pan plug at the side instead ot right under front drive shaft........and lastly why not a longer drain line so it at least protrudes a bit through the frame....any easy ideas on replacing banjo fitting apprecited-tia | |
