KMech - 5/12/2019 08:13
tedbear - 5/12/2019 06:38
A concern would be that the half width disconnect clutches on the planter may have a considerable electrical draw. This often exceeds the Clutch module's current handling ability as the Clutch Module needs to provide ground to cycle both clutches OFF at times. A HD relay at each clutch would solve that problem. With the relay, the electrical load of actually cycling the clutch OFF would be carried by a pair of heavier wires leading directly to the battery on the tractor. Then the Clutch Module only needs to operate the coil of each relay which it can handle easily.
Apparently this has not been a problem with your drill but would be a consideration with the planter clutches.
Two clutches is no problem for a clutch module. You can go to three, and maybe have to deal with an occassional fuse burnout. Four is the point where it becomes troublesome. Four is the point where I use relays to offload two of them from the CCM. I have never seen two be a problem.
