| Precision's 727027 harness will power the globe through a 2 pin weatherpak usually from the ccm or the 3 to 2 pin adapter (700242) mentioned previously, that cable would take care of A and C.
https://cloud.precisionplanting.com/pubs/?view=0BwSYzyFHvNvUWjJ3S21l...
I don't believe the 727027 allows power through the 9 pin agleader port so in your B case you would either have to find an auxiliary 2 pin power (could be that same 700242 harness) to use the 727027 or use agleaders single or dual port cable which does allow the Integra to power the GPS.
In your C case you could also use agleaders dual port and use port A to power from the integra and then use precision's x adapter cable on port B. | |
