| To answer your questions:
1: The Edge will not run the EZ-Steer. You can only use the On-Trac2 or hydraulic Paradyme system with that display.
2. The only Ag Leader branded displays that will run the EZ-Steer is the EZ-Guide 500 or EZ-Guide Plus that have Ag Leader stickers on them.
3. For more accurate signal, the 2500 will work great with the Edge display and can be unlocked all the way up to RTK. Ag Leader doesn't sell those any longer but there are some used ones out there if you are looking to save some money. The GPS6500 would also work great with that display. Otherwise the current GPS7500 can be unlocked all the way up to RTK as well. There is a caveat with the GPS 6500 and GPS7500, they will need to be connected either a newer display like the Integra, Versa or InCommand series to set the correct GPS settings for the Edge display or to a laptop connected to the Novatel Connect program. Again, not difficult but just something to note.
4. You will need to have the switchbox hooked up. It won't allow you to load the configuration without seeing the Aux Input Module.
