Southwest Minnesota | Have incommand 1200 it runs everything on the planter with ag leader modules.
The universal terminal shows the planter but I only use it to see vac pressure.
1910 cart is pulled behind planter, universal terminal also shows the cart. Shows all pertinent info and I switch tanks and turn the delivery system on and off with it manually.
Is there a way to have it turn the air cart on and off automatically when I raise or lower the planter?
Using an implement switch or???
Thanks | |
