Search Forums | Classifieds (154) | Skins | Language
erratic speed on jd 2600
coyotehunter
Posted 5/8/2019 18:21 (#7484662)
Subject: erratic speed on jd 2600
planting set up
cfx-750 auto steer imputing speed into jd 2600 for planter. ag express cables.
we will plant 10-20 acres normally then the speed on 2600 will jump up or down 50-70 percent resulting in the hyd drives shutting off. speed on 750 does not do that. it will go through this spell for a few acres, sometimes shutting off the 2600 will fix it. then we can plant again for abit before it does it again. it makes for along day.
we also will run a raven 440 monitor for nh3, also imputting speed from the 750 into the 440 and have no problems with the speed issue there whatsoever.
thoughts?
