WC MN | So a setting must've gotten changed on FieldView so when we get close to other field boundaries the fields on the displays change by themselves. I got that problem fixed but now data is on wrong fields. Example: Planting soybeans on Field A, got too close to Field B (corn) and display switched from Field A to Field B. Now when I look at my reports/maps I have soybeans planted on small portion of Field B which is not true. I went to Climate.com to see if I can edit the data and doesn't appear that I can. Anyone know how I can switch these small pieces of data to the right field so it doesn't screw up my reports/maps? |
