Central Minnesota | 2011 year. Not HID lights. They suck. I probably should buy some tiger lights or something.
But, I was wondering if there is any way to change the wiring so the road lamps will also go on with the field lamps. Seems having 2 more lamps in the field would help. Almost seems like the 2 road lamps are better then the field lights.
I suppose I could slice a wire in with the field lamps, but might be to much draw on that circuit? | |
