NE Nebraska | Reverse polarity can be changed as a setting in the display, you don’t need the old relay box used for clutches.
Power and ground must be supplied to the ezboom via pins 1 and 16 on the 16 pin amp connector. I don’t remember which is which but I’m pretty sure a search would tell you. That is where the ezboom gets power to supply everything it does. Valves, flow meter, implement switch, rate control, etc. if your valves require high amp draw, then using a relay to isolate them would be necessary.
There should be a power indicator light I believe located near the master switch. That should be green I think when ezboom has power and display is turned on.
Good luck
