roaming | Farms With CASE - 5/3/2019 14:12
I need to setup a 162 to output NMEA with VTG, GGA, and RMC all being turned on. Tried using the Pro600 to do it and I can change those settings but they reset on a power down. Tried AgRemote but the same thing happens. Why can't I get the settings to remain even with AgRemote? What am I not doing correct? Even had local dealer try his laptop and still a no go. He tried a 162 on a combine in their lot, no go there too.
What version of AgRemote are you using, and what version of 162 firmware? If I understand you correctly, you set VTG, GGA, and RMC to "enabled" (all uppercase), then press the Enter button to save your settings, then disconnect, and when you reconnect AgRemote, all three settings are back to lowercase? |
