| Tricky SOB.
When connected to PC com-port for checking / changing settings like FLOW do you get any response at all to your PC terminal program from "FLOW=?" or "FLOW= ?" commands?
If not, then the connection to PC is not OK.
When hooked to 500 and (after maybe also making a hard reset on the dongle) starting everything up what does it tell you in the:
1) status popup window of 500
2) log area of Lefebure Client
You might maybe want to get a Parani Senna. It will let you do setting by microswitches.... | |
