| what application are you using it for? Autopilot? It could be a setup issue with the autopilot settings, sounds to me like settings in the NAV are causing it to calculate position wrong based on one or more of its sensors, which explains why if you sit still, the offline distance comes back to zero. If so, you could try to update the display and NAV and re-calibrate the steering. | |
