| I bought a used gen 1 20/20 system with the original smart connector for my kinze 2100 plot planter. All I want to do is monitor skips doubles population and speed etc. I'm not worried about the guage wheel load right now as I just need to be planting plots with it. I've got the 4 pin connector plugged into the smart connector and the planter harness plugged into the opposite side of the smart connector. I've got blinking lights on the smart connector so I know I've got power there. I tried one display and that didn't work so I figured the display was bad so the guy I bought it from gave me a different one that he tested and made sure it worked first. However this second one won't even power up at all for me. I've checked the fuses and they are good and if they were bad I would assume the smart connector wouldn't even power up. I've also looked at all the pins in the harnesses to make sure something didn't get pushed out and can't see anything. Any thoughts or advice? | |
