Search Forums | Classifieds (150) | Skins | Language
Trimble 262 RTK/RTCM to Ez Guide 500
case
Posted 4/15/2019 17:49 (#7441205)
Subject: Trimble 262 RTK/RTCM to Ez Guide 500
Central ND
Trying to setup a 262 with RTK and an EZ Guide 500.
In the EZ Guide 500 you can set it to get external TSIP or also external DGPS corrections, with TSIP I don't have the option to do NMEA output but with the DGPS corrections, I can.
My question becomes, can I still use RTK with the 262 but set it to output RTCM to the EZ Guide 500 for external DGPS corrections, then I can still do NMEA output from the 500 as well?
What do I set the 500 to for sending back to the 262 as it has baud rate and some other things?
Long story short, wanting to send RTK to the EZ Guide 500 via a 262 with RTKonnect. Then I want to NMEA output from the 500 to a pro 600. Using external TSIP in the 500, I can't NMEA output thus the question on DGPS corrections using RTCM from the 262
Shouldn't the 262 be able to do all the RTK corrections internally and then just output via RTCM 2.0 for DGPS positioning to the 500? Or am I confused about it all?
Edited by case 4/15/2019 17:57
