Oregon | to barbed wire to the back of this cluster then I’d have it all haha.
Been working on getting our farm ground (been in sod for a hundred years and wore out) rotated and into double crop grain hay with a winter forage mix behind that. This is the last field to tear out then hopefully no till from here on out. Would of no tilled this one into barley but was way too rough. Couldn’t get into it last fall because we were feeding cows here. Had to bust the sod with an offset disc this spring which made some clods. This setup is working pretty good at getting them out. Not pretty but it’s what we have so it’s what I use. Had to rob the tire and cylinder off the ring roller to get the ridgid harrow mobile. Leaving ridges but should be able to knock them down next pass.
(A1F05718-C582-40F5-9916-C605C02989E0 (full).jpeg)
(AB1530AE-2C23-4588-91AB-9913DF26ED55 (full).jpeg)
(0BF348D5-D08D-41F0-950F-70103F1453F1 (full).jpeg)
Attachments ---------------- A1F05718-C582-40F5-9916-C605C02989E0 (full).jpeg (369KB - 109 downloads) AB1530AE-2C23-4588-91AB-9913DF26ED55 (full).jpeg (545KB - 121 downloads) 0BF348D5-D08D-41F0-950F-70103F1453F1 (full).jpeg (284KB - 85 downloads)
