Classifieds (89)
Air switch in semi
Machinery Talk
jd4930
4/15/2019 11:02 (#7440666 - in reply to #7440654)
RE: Air switch in semi
Central ND
You need to push the brass collars in and then pull the hose out but if you are replacing the switch I would just cut em off
Air switch in semi
AGDEAL
: 4/15/2019 10:56
jd4930
: 4/15/2019 11:02
AGDEAL
: 4/15/2019 11:15
Farms With CASE
: 4/15/2019 11:30
ne_mn
: 4/15/2019 13:06
jd4930
: 4/15/2019 13:08
BigDave
: 4/15/2019 13:25
ne_mn
: 4/15/2019 13:35
jd4930
: 4/15/2019 15:15
CASE3594
: 4/15/2019 17:49
WTF2014
: 4/15/2019 15:33
AGDEAL
: 4/15/2019 15:53
WTF2014
: 4/16/2019 15:44
NEILFarmer
: 4/15/2019 17:33
82farmer
: 4/15/2019 19:00
