Lancaster County, Pa | What you have is a power beyond block on top of remotes..This is often used for loader valves... Basically ports to pressure,return and load sense signal...Loader install instructions may direct you in how to properly install.
The coupler to left of top link is motor return..Ported directly into return line so oil doesn't have to be forced back through remote valve stack...You still will have some pressure there(not zero pressure return) | |
