2630 and implement switch
rollig
Posted 4/15/2019 09:30 (#7440494 - in reply to #7436379)
Subject: RE: 2630 and implement switch
SCMN
All an implement switch is in that system is a short.  The switch just open or closes the circuit.  You can set in the 2630 whether it's set to normally open or normally closed.  I believe it's under the equipment setup on the page where machine offsets are changed.
