Help! - John Deere 2600 Display / Operations Center / Export / Import Data
bmatteson
Posted 4/12/2019 14:51 (#7435561 - in reply to #7435279)
Subject: RE: Help! - John Deere 2600 Display / Operations Center / Export / Import Data
NEND
Setup data does not go into Op Center from your card at this time. You have to input your equipment in Op Center. And you are correct, once you put data from Op Center on your card for your 2600, your current setup data will be replaced with the info from your new setup file on your card. So make sure you note all your machine and implement dimensions on your current card for your 2600. Another option is to get a new card for it in case you miss something when you make a new card. It sounds like you’re figuring out where things are on Op Center, it’s relatively intuitive. There are a bunch of YouTube lessons on it, but some might be outdated as they have changed some things recently. I don’t think Setup Builder has changed too much though
