NCND | When applying nbpt to UAN the rate required is half the rate for urea. So if your urea rate is 3qts a ton UAN would be 1.5qts ton since only half the N in Ian is urea and the other half is stable.
Franzen from NDSU says need about 1.3lbs active per ton to get the benefits of nbpt.
Dudek saying nbpt doesn’t work is like saying there is Russian collusion. It’s not true. Simple fact. Tons of data that proves nbpt works as advertised. | |
