Central Nebraska | I am trying to export RTK from an FMX with an Ag25 antenna into a Viper 4+. I have the right cable. I am exporting NMEA VTG, GGA, ZDA and RMC. I have RTK fixed on the Viper, but no VTG when I try to create a line. I think the problem is the FMC is exporting all NMEA at 5 Hz. Is there a solution? I've tried various baud rates from 19,200 up. I've tried lowering the speed to 1 and 3 Hz and then it loses GGA. I added the RMC as it wouldn't get RTK fixed until I did, even thick I have never seen it called for. | |
