Posted 3/23/2019 14:23 (#7397159) Subject: Steiger 350 Greenstar help
Western Kansas
Installed Greenstar autotrac kit on a 2013 350 Steiger last fall, everything works as it should other than the 2630 isn't communicating with the SCVs to map when doing tillage. Tractor has 5 SCVs and it only shows 4 when you select which to use as recording source. I've tried using one of the other 4 and it never does kick the recording on. Any help would be appreciated.
