south central, KY | We took our newly converted DB90 to the field today to give it a try. We made several test runs and the v-sets and speed tubes were working correctly as far as we can tell. The delta force seems to be working but I am trying to figure one thing out. If I have my margin set at 80 I could only get around 30-40 lbs of margin. So I set the margin at 150 and get around 80-100 lbs of margin. Why isn’t the margin running where I have it set? It is constantly in the yellow and never green like everything else. This is in ripped ground that had cultivator run over it to smooth up some. Still s little rough, as it is some red clay cloddy ground. Maybe this is normal as it is showing 99-100% ground contact but I assumed the margin would run where it was set. TIA | |
