Northern Nebraska | If you search for Nelson impact sprinkler I believe you will find what you are looking for.
They work just like the little plastic ones in for the yard. Water flow is nozzled down at the end of the sprinkler increasing velocity. The water hits a pad on a spring loaded arm that breaks up the steam. The impact also turn the entire unit a little bit.
Edited by Hilltop Husker 3/20/2019 07:24
