Cen. Pa. | I use 6-24-6 corn starter it's a pop up I run it through Keaton firmers and apply 4 gallons per acre in the seed trench right with the seed. I use capture LFR and I'm thinking about switching to Brigade this year to save some money... is Brigade equally as cat compatible with the liquid fertilizer.. ? It is applied buy an electric pump through orficed manifold.. I currently do not have agitation in the fertilizer tanks.. the capture LFR stayed in suspension pretty good in the past if I had to stop for any length of time I have an air bung , and I just plugged it in and use d air to agitate the mix in the tank on the planter. Just wondering if anybody uses Brigade in this type of an application
