Posted 3/15/2019 13:37 (#7382254 - in reply to #7382224) Subject: RE: Cat 45 Hyd Remote Cable
I think if you back the jam nut off on the end of the cable then undo allen head bolt that holds that piece to the scv valve, you then unscrew the piece that you took the bolts out of that should expose the end of the cable where it hooks to the spool in the valve.
