Search Forums | Classifieds (100) | Skins | Language
MF 11x5 Cab and 3pt Questions
Massey1155
Posted 3/14/2019 19:43 (#7380863 - in reply to #7380808)
Subject: should be a few in your area to look at
NW Iowa
Might be easier for you to just go drive one. Plenty on tractor house to look at. Hard to go wrong, you can buy a excellent one for under $12000. Needing cab interior and paint for around $6500. I think you've set the record for questions on them.....
They have adjustable sway blocks if you need to. When you raise it all the way up there is very little side to side play. Had the heaviest 3 point you could buy.
The cabs are very roomy. If the cab bushings are good, cab interior is relatively new, and floor mat is in it, they are very respectable.
Pretty rare to tilt the cab back. There is a big access plate in the floor to get at the charge pump.
No buddy seat, used to flip the arm rest back and sit on the edge of seat and fender padding. Plenty of room for a kid, another big guy not so much.
It's not like a 90's or new tractor by far. If you want lots of comfort going to have to spend more money. If you want a good running decent priced older tractor, they are hard to beat.
Edited by Massey1155 3/14/2019 19:53
