Search Forums | Classifieds (76) | Skins | Language
running clutches with 162 or 252 receiver
raider2b
Posted 3/14/2019 06:55 (#7379389 - in reply to #7378593)
Subject: RE: running clutches with 162 or 252 receiver
North Dakota
The problem I see is not the receiver but the correction for the clutches. WAAS will shift your lines over a short period of time. Most often noticed when you stop to fill the planter and return to the field you could have shifts of 4 or 5 feet. If you are OK with that then it isn't a problem.
If the Ag Leader has a better correction source I would still use that for GPS into the 700. The 700 can receive GPS in NEMA format through the RS232 serial ports or through the CAN in NEMA2000 format.
