Qulin, MO | You can reuse the same Grower/Farm/Field you just have to start a new Operation Instance (think that’s what it is called) to reset your coverage map and acre counter.
If you are using it in a autoguidance ready Case IH machine it can start/stop coverage using one of the remotes or the 3pt hitch. If you are using it on another machine you would have to manually turn coverage mapping on and off on the screen. | |
