Search Forums | Classifieds (146) | Skins | Language
If you were cutting an auger tube like so, where would you locate the seam?
JAnderson
Posted 3/13/2019 17:36 (#7378344 - in reply to #7378196)
Subject: RE: If you were cutting an auger tube like so, where would you locate the seam?
McCanna, ND
Usually it seems like the seam usually isn’t perfectly round like the rest of the tube is. If that’s important to you I would cut the seam out. When the local welding shops make liners they cut the seam out to slip it into the existing piece.
