Posted 3/12/2019 21:00 (#7376589 - in reply to #7376491) Subject: RE: Sprayer tips and speed questions
Swaledale, IA
Since you are on 15" centers the 80 degree tips might be better. Unless you are in really big square fields that are pretty smooth 10 mph is a pretty good top end at least doing your own. If custom applying you might want to push it a little faster. The extended range or an air induction type tip both handle the range of speeds you will go in a self propelled.
