Posted 3/13/2019 06:15 (#7377046 - in reply to #7376286) Subject: RE: Adjuvants designed with residual chems in mind??
Southeast WI
Can you explain the all elusive "works well"?
I've been spraying crops on farm since the '80s and use normal adjuvants/ams/ etc as recommended. I personally can't discern when one works better other than if it's misused like applying with NIS when MSO is required.
This is a real question. What are the parameters that convince one to use a different product than the standard more generic adjuvants?
