Austin MN | Here it is. Not much to look at. Drum spins 30 rpm. We put a pro box under the outlet and pick up a full box with the forklift and run it through. I timed a couple boxes through it with applying treatment. I can get roughly 500 lbs a minute through it. I use a small inductee with a small diaphragm pump with a cp nozzle off our airplanes to spray. I adjust the pressure to measure out so the volume I need per minute to match seed flow. It works pretty good overall.
(20190313_095151 (full).jpg)
(20190313_095202 (full).jpg)
(20190313_095310 (full).jpg)
Attachments ---------------- 20190313_095151 (full).jpg (137KB - 40 downloads) 20190313_095202 (full).jpg (113KB - 39 downloads) 20190313_095310 (full).jpg (142KB - 35 downloads)
