SE Nebraska, Near Misery and Cans Ass! | I'm assuming this is a partial. Add 25% water if you can plus one gallon of a very good Nis like preference.use the recirculation on the pump or pump it back and forth between there in an empty shuttle. Of course you will have to adjust your rates of mixing accordingly. If you cannot go up to 50% water that will help even more. it's also easy enough to take a piece of half inch rod and put a loop on the end of it and use a slow speed drill to agitate with. I'm not a fan of using air to agitate this product is it takes forever to come out of it and makes measuring volumetric very difficult, you need a scales.. I've always smiled with the commercial places that stick and air hose in atrazine or lexar and then fill their Riggs and go out to spray. sure does increase their profit margin! |
