| Had a stretch of cold weather and now tractor won't get fuel to and thru water separator filter
Worked thru new filters, meltdown into tank that was already straight #1 fuel for Dakota weather
This tractor doesn't have the small inline fuel filter vrs newer sn# models
Down to order and install new primer pump mechanism on top of fwd fuel filter
Apparently that also pulls fuel from tank as much as it is a hand primer
No bleed screw on or near pump)?......not that we can see
Do we need now to crack fuel lines into engine block to get air out once primer installed
Thanks | |
