E SD | Epson printers do a great job in print quality because of how the print head is designed. It stays on the machine vs the HP's that gets replaced with the cartridge.
The tradeoff is the head gets plugged if not used all the time, or if the machine doesn't turn off and on and cycle more ink. You can try the kits to unclog the head, but you will end up junking the machine.
All you have to do is search " Epson skipping lines". Mine lasted 1.5 yrs along with buying $50 of ink.
For black & white invest in a laserjet, they are the best deal long term.
$200
https://www.amazon.com/HP-Laserjet-Monochrome-Printer-Replenishment/...
Edited by Womp 2/26/2019 10:07
